I exported an XML file successfully and then imported it into another drawing....no problem. I then tried to export several point groups from one drawing to another and I keep getting the error "not a LandXML file". What could be causing this? I am doing the same exact thing as I did the first time. Is it because there are too many point groups?
Are you exporting/importing from and to the same computers each time? Are the Civil 3D versions the same? Also, are you exporting as LandXML 1.2?
Mike
