MatiasJr wrote:
> New to Civil 3D 2006. I've created a surface using a DEM file. I've
> created a profile view with an existing ground line profile and a
> proposed grade profile for an imaginary ditch with a certain slope.
> The ditch has a depth that varies from about 10 to 16 feet. I've
> created assembly with subassemblies that give me a desired section
> (includes) benching. I've created a corridor that uses this assembly.
> The final (top) subassembly on each side of the ditch (symmetrical
> about center) has been set to daylight to the exist ground surface in
> the corridor properties dialogue box (I suppose this can be
> accomplished by using different combinations of subassemblies). My
> problem is that when I place the sections most of the assembly plots
> in every section with the exception of the final (top) subassembly. I
> don't get the existing ground line either. I performed the sampling
> of sections with sufficient swath distance too. What am I
> overlooking. The ditch section consists of an almost flat slope at
> bottom, then a 3:1 slope, then an almost flat bench, and finally a
> 3:1 slope that daylights onto the exist ground on either side. (By
> the way what is the easiest way to create such an assembly with all
> the different options available?) Can somebody lend a helping hand
> with this?
I ran into a similar issue today with C3D 2008. EG won't show on my
section views when I use a DEM file as a surface. I talked with QA,
who verified that it doesn't work. So, I guess it's a known issue....
Jason Hickey
Civil 3D 2008, SP1
Dell Precision M70
2 GIG RAM, 256 MB nVidia Quadro FX Go1400
Intel Centrino 2 gHz Processor
www.civil3d.com
