AutoCAD Civil 3D General
Active Member
Message 1 of 9 (225 Views)
need help deleting surface
225 Views, 8 Replies
08-29-2013 01:28 PM
ok i have tried everything like selecting the surface from the procperctor and pressing delete but freezes civil 3d
i will email a link to the file to you and see if you can delete it
please someone help me
LisaPohlmeyer
Message 2 of 9 (218 Views)
Re: need help deleting surface
08-29-2013 01:44 PM in reply to: htls69
what version?  I'll give it a go.  lpohlmeyer at wilco dot org
Lisa Pohlmeyer
C3D 2012 SP4, holding off on C3D 2014
Please use "Accept as Solution" if this solved your issue.
Active Member
Message 3 of 9 (211 Views)
08-29-2013 01:50 PM in reply to: LisaPohlmeyer
using civil 3d 2014
send file to you
LisaPohlmeyer
Message 4 of 9 (200 Views)
08-29-2013 02:10 PM in reply to: htls69
if it's larger than 8Mb, it'll bounce. You'll have to use Gdocs, Dropbox, or something else. Sorry.
Lisa Pohlmeyer
Active Member
Message 5 of 9 (197 Views)
08-29-2013 02:15 PM in reply to: LisaPohlmeyer
i sent you a email with dropbox link
Active Member
Message 6 of 9 (174 Views)
08-29-2013 03:29 PM in reply to: htls69
so she tried and she could not do it  maybe someone else can try
Jeff_M
Message 7 of 9 (169 Views)
08-29-2013 03:41 PM in reply to: htls69
jeffm AT quuxsoft DOT com
I will have a look
Active Member
Message 8 of 9 (164 Views)
08-29-2013 04:44 PM in reply to: Jeff_M
here is the file
here
Active Contributor
Message 9 of 9 (120 Views)
08-30-2013 03:34 AM in reply to: htls69
If you wont be able to delete surface after "audit" , just export everything to xml and import it to new dwg file
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
