AutoCAD Civil 3D General
Active Member
gelinase
Message 1 of 4 (332 Views)
multiple surfaces lowest elevations
332 Views, 3 Replies
04-30-2012 07:34 AM
I have many surfaces overlapping and I want to create one surface with the lowest elevation for each x,y coordinate from the existing surfaces. Does autocad civil 3D have a command who can help me?
Thanks.
Joe-Bouza
Message 2 of 4 (316 Views)
Re: multiple surfaces lowest elevations
04-30-2012 09:53 AM in reply to: gelinase
This sounds like Dejavu all overagain.
If you make volmume surfaces you can extract the zero contours to use as boudaries to the lower surfaces. I would expect to see a jigsaw puzzle that dovetails together. The make a new surface"combined and paste all the "Cut" areas into combined.
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
Active Member
gelinase
Message 3 of 4 (310 Views)
04-30-2012 10:25 AM in reply to: gelinase
Member
Civil_Engineer_In_Irvine
Message 4 of 4 (242 Views)
09-14-2012 01:22 PM in reply to: gelinase
Yes like that post...... which I watch every day in hopes of a better way.
It is very tedious work if you have a lot of survey and surface information.
Should be done congruently with the survey
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
