AutoCAD Civil 3D General
*Expert Elite*
Civil3DReminders.com
Message 11 of 17 (110 Views)
Re: moving pipe or structure from one network to another
07-31-2008 01:42 PM in reply to: lgs663
Yes you can.
Civil Reminders
http://blog.civil3dreminders.com/
http://www.CivilReminders.com/
Distinguished Contributor
Message 12 of 17 (110 Views)
07-31-2008 01:51 PM in reply to: lgs663
i found it - thanks
why couldn't i use that as a structure table
(might work)
*wfb
Message 13 of 17 (110 Views)
07-31-2008 01:52 PM in reply to: lgs663
While beating this dead horse "more deader". The LandXML out will only
include the pipes/structures that are to be changed to the other network.
Bill
wrote in message news:5995826@discussion.autodesk.com...
Two 2s by mistake.
I meant, you can't export/import particular pipe/structure. If you left
"features not to be moved" in xml file, they will be imported and you will
have doubled structures and pipes.
*Expert Elite*
Message 14 of 17 (110 Views)
07-31-2008 02:17 PM in reply to: lgs663
It would work, just lots of overhead managing the labels, especially when they move.
Christopher
http://blog.Civil3DReminders.com/
Civil Reminders
Message 15 of 17 (110 Views)
07-31-2008 03:23 PM in reply to: lgs663
okay - does anyone know why my label is doing this on some structures and not others
(see attached)
csevers
Message 16 of 17 (55 Views)
12-12-2012 02:06 PM in reply to: lgs663
So this was never solved? Nobody knows the command to swap networks, similar to swap parts?
Chris Severs, EI
Windows 7 x 64 bit
NVidia Quadro 2000 Dual Monitor
6.00 GB RAM
Intel Xeon W3550 @ 3.07 GHz
Civil 3D 2013 SP 2, Civil 3D 2012 SP2, Civil 3D 2011 V3, Civil 3D 2010 V3
*Expert Elite*
Message 17 of 17 (54 Views)
12-12-2012 02:18 PM in reply to: csevers
I believe since 2010 you can split and merge networks.  So split the items from the network they're on, then merge that new network into the one you want them on.
Credit where credit is due! Give kudos or accept as solution whenever you can.
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
