Solved by troma. Go to Solution.
I believe since 2010 you can split and merge networks. So split the items from the network they're on, then merge that new network into the one you want them on.
Mark Green
Working on Civil 3D in Canada
i love this, been 11 years and i'm still not seeing a decent answer.......................
such a shame
Select all the pipes and structures that you want to move and choose the "split network option, and then it will give you the option to select the network that you want to move the parts into.
