Civil 3D Forum
moving and rotationg....did i mess something up
8 REPLIES 8
Message 1 of 9
Rubixcube10
435 Views, 8 Replies
I created a deed plot using the create a line by bearing.  I've done this before.  Sometimes everything work right...sometime it just baffles me.  Anyways.  I created it and rotated it.  All ok.  Then when I went to move it, the whole figure wouldn't move.  When I try to rotate it again...it makes lines longer and shorter than what they were.  I've included 3 pics.  The 1st pick on the normal figure, the 2nd pic trying to use the move command but only a portion of the figure will move.  The 3rd, is trying to rotate it and you can see it's not rotating right at all.  I'm curious if I clicked/unlicked sometype of command by pressing a certain key on my keyboard.  I've read "Shift" key does something but don't understand.
Thanks, Robert
Rob
HP Compaq 8100 Elite
Win 7 Pro SP1 - 64Bit
8GB RAM
i7 860 @ 2.80 GHZ
AutoCad Civil 3d 2012 SP1
8 REPLIES 8
Message 2 of 9
Jay_B
in reply to: Rubixcube10
Could you post a caption of the deed with the grips enabled so the expected segments are visible?
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 3 of 9
Rubixcube10
in reply to: Jay_B
Is this what you're looking for?
Rob
8GB RAM
i7 860 @ 2.80 GHZ
Message 4 of 9
Jay_B
Yes thanks, It looks like the 1 line segment on lower right may not be included in the selection set
as in your 3rd capture.
The shift key thing you mention can be used to remove selected items from an active selection set.
This is done by holding shift key and selecting a selected entity = removed.
What happens if you select by a "window" selection and carry out the command?
If this doesn't help try posting the dwg here.
C3D 2018.1
C3D 2016 SP4
Message 5 of 9
Rubixcube10
in reply to: Jay_B
Jay,
I usually window the whole thing when I move and rotate.  It looks like 2 line segments don't want to work right.  when I delete those two segments everything works fine.  Here's the dwg.
Rob
8GB RAM
i7 860 @ 2.80 GHZ
Message 6 of 9
Jay_B
Thanks for posting the dwg.
I'm no expert on Constraints but if I run the DELCONSTRAINT command on the entire red outline in the dwg,
then the linework moves normally.
It appears to be a Constraints issue @ point X=  3441.40  Y=  9669.63.
The little blue glyph you get when hovering over the linework is indicating constraints have been applied to the objects.
C3D 2018.1
C3D 2016 SP4
Message 7 of 9
Rubixcube10
in reply to: Jay_B
Thanks Jay.  I'll have to remember that command.  Is there a reason why it automatically applies constraints?
Robert
Rob
8GB RAM
i7 860 @ 2.80 GHZ
Message 8 of 9
Jay_B
Robert,
Most likely the Infer Constraints is active by having the icon active on very lower left of screen.
If on, Constraints will automaitcally be applied as the geometry is drawn.
HTH
C3D 2018.1
C3D 2016 SP4
Message 9 of 9
Rubixcube10
in reply to: Jay_B
I see.  I have now turned it off.  Thanks again!
Rob
8GB RAM
i7 860 @ 2.80 GHZ
Rail Community
