For my dimension style, I have my text placement set to over dimension line, with leader, so I can drag the actual text outside the dimension line with a leader attached when necessary, but when I try to move the text outside of the dimension line it always draws the leader underlining the entire piece of text that I have moved. Is there a way to control the leader to attach to the middle of the line and not underline the entire piece of text when doing this operation?
thank you
Post a drawing.
@wbrustle wrote:
Here is a drawing with the dimension text I am referring to...Is there a way to attach the dim line leader to the middle of the text line and not underline it?
You forgot to attach...
Did this ever get resolved? i have the exact same issue. when using "Over Dimension Line, with Leader" for text placement, it automatically unerlines the text. I would like for it to automatically attach to the midle of the text box.
