Solved by Pointdump. Go to Solution.
Mc,
To change the scale in Civil 3D, thusly:
Dave
Dave Stoll
Las Vegas, Nevada
What units? Feet, Inches? Meters, Millimeters? If Feet area you drawing you're architecturals in a foot based drawing or an inch based drawing?
Allen
Allen Jessup
CAD Manager - Designer
OK. If they're both real world millimeter drawings. Use the method Dave posted. No conversion or scaling needed.
Allen
Allen Jessup
Mc,
Settings Tab, right-click the drawing name and select Edit Drawing Settings. On the Units and Zone Tab you can choose your units and drawing scale. I didn't see a 4000:1 in the list so you might have to select "Custom".
Dave
Dave Stoll
Las Vegas, Nevada
Mc,
What variant of AutoCAD are you using? This is the Civil 3D Forum, so I assumed you were using C3D.
Dave
Dave Stoll
Las Vegas, Nevada
Mc,
I was going to recommend you try posting in the Architecture Forum. I see you already have. That's probably the best place to get an answer to your question.
Dave
Dave Stoll
Las Vegas, Nevada
