Is there a way to space the text above the underline for mleaders? Currently, the text sits right on the line (setting is underline top text) such that for example, the bottom line of the capital 'E' blends in with the underline.
Solved by Jay_B. Go to Solution.
Hi Tim,
Perhaps these settings in the MultiLeader Style will correct it:
Dave
Dave Stoll
Las Vegas, Nevada
Hey Tim,
I hate to give the 'It doesn't happen here' reply, but...
You might try adjusting the line space distance and/or the line space factor under Text in the properties window.
Kirk
Post a dwg that includes a few of these Mleaders so someone can take a look.
Changing the Linespace Style to "Exactly" in Properties Palette with all of the Mleader text selected improves all but one Mleader in the attached dwg.
Idon't know why the 2nd note down won't adjust as there's another similar note near bottom which also includes a forward slash.
That worked. Thank you!! Ended up just replacing that callout with one that worked..(it is odd that 2 callouts that have the same text content are showing differently)
