I am trying to load .dwg files off a filetransfer site, when I load them I get popup messages saying there are missing .shx files and also missing referenced files. It asks if I want to locate them or ignore them. Since I am getting them off a file transfer site I can't locate them I'm sure. Is this an error I am causing or are they within the .dwg file. Also the drawing seems to load properly, but if I try to combine them with another drawing using copyclip command parts if not all of the drawing will disappear on the other drawing. Are these related? Thanks for any help!!
Further to R.K.'s post, if you open the xref dialog, you will see which xrefs are missing. They may or may not be important. YMMV.
