I just created a surface called "existing" using existing polylines. I have a boundary showing up around what would be the limits of that surface. I am trying to "show" the contours because right now all I can see is the new boundary, and the polylines from which I made the surface. I want to view my new contours as a check, but when I go to change the style, all I see is "standard" and my new contours still don't show up. ANy body know what I might be missing to make my new contours show? I'd appreciate any help. Thanks
Solved by SethHall. Go to Solution.
Hi Mike-
You will need to edit the Standard Surface Style to "turn on" the major and minor contours for them to show up:
Hope this helps!
