Civil 3D Forum
lowest point on a closed feature line
7 REPLIES 7
Message 1 of 8
1402 Views, 7 Replies
Good Day,
Is there a easy way of know what the lowest point on a closed feature line is.
Example:
I am placing a reservoir on the side of a hill. Draw a polygon with 25 sides make it Inscribed and create a feature line from object. I assign the ground elevations to the feature line. Under the feature line elevation editor you get a list of elevations but you cant 'sort' them.
I usually resort to taking the polygon and making a slight break in the line. Then I creat a profile from it and do a inquiry on the lowest point. Then I just do a undo.
Is there a tool I am missing.
Regards
Rob
7 REPLIES 7
Message 2 of 8
Jeff_M
The Properties Palette shows the Minimum and Maximum elevations. If you need to know which vertex is the lowest, then the Elevation Editor is probably the best bet.
Message 3 of 8
in reply to: Jeff_M
Thanks.
Message 4 of 8
neilyj666
You could select all and paste to Excel, find and replace the unit (e.g. m in metric versions) and sort
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 5 of 8
Jeff_M
Rob
With just a wee bit of programming this is a fairly simple thing to do. Here's a pic showing the results of some code I just wrote that shows both the High & Low points (yellow & green circles respectively). I will post to the C3D.Customization forum both the source code and a compiled .NET DLL that you may load (using netload) and run the command FEATUREHIGHLOW.
This is not a full featured command, as the circles are a fixed size, I only allow Featurelines or 3DPolylines to be selected (Survey figures, Parcel Segments could both added be used if desired). However, since it is a .NET solution, it works in C3D 2010 through 2012 without any changes required.
Hope it helps a bit.
Message 6 of 8
Joe-Bouza
create a surface and read the contours - that is what we do, no?
Joe Bouza
Message 7 of 8
neilyj666
in reply to: Jeff_M
Jeff has come up trumps again with his programming skills.......!!!!! Hats off to you,Smiley Happy Sir....
Message 8 of 8
BrianHailey
You could create a surface at elevation 0 and another with your featureline and then use the minimum distane between surfaces command.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Rail Community
