In some templates I can't load a custom North arrow. AutoCAD can't find block.
The built-in north Arrows works fine. In a standard template from Autodesk there is no problem.
Wich settings should I change so I can select a block?
Kind regards,
Nico
I am not sure what you are doing, however, using Design Center, (DC) you should be able to drag you block into the same file that other Arrows are located.
Bill
Infrastructure Suite 2014
In civil 2013 yo can use Dynamic North Arrows. This arrows are connectect with a viewport. if you rotate the arrow the viewport also rotate.
But in our corparate template i can't select our own block for this arrows. only te standard arrows.
And de drawing contains the block.
I'm seeing the same thing in c3d 2014. The block exists in the drawing, but nothing shows up in he custom block dialog.
this is an inconsistent poroblem -- some drawings work, some work once, and some always work. damifino what's triggering the difference.
For a workaround... You could RENAME the default standard block to your company's north arrow block name. Then you could insert the block from your library to redefine the linework.
Don't have the latest versions loaded to play with these dynamic north arrows so I have no idea if you can do this!
I'd still like to be able to choose, but as a workaround, I inserted my company standard North into the "Map - North Arrows.dwg" , (in the Samples folder uncer Civil 3d) and it shows up in the list of built-In north arrows.
i can still browse to other drawings to grab a north arrow dynamic block fromn that tool (or any block really...) but Current Drawing is not displaying anything,
Are you sure it is not in your drawing but really tiny?!
I tried to do the same with our N-arrow but it kept coming up as microscopic?
It would be really nice if there was a tutorial for using custom north arrows (in both metric and standard) this... is there a tutorial for this?
Once I insert the block in Paperspace, it's properly visible and the correct size. The problem is, that even though the block defintion is in the drawing (and can be placed using the INSERT command), the listing under "Current Drawing" is empty.
Adding my company standard block to the sample Map north arrow drawing works, but doesn't fix the problem. I'd rather rely on using my template drawing for company standard blocks instead of using an OOTB sample that may or may not get overwritten with a Service patch or Repair/Reinstall
I haven't seen a tutorial -- possibly look for something under the Map3D documentation? since the command that actually places the arrow is a Map command.
I was looking for info on making a custom north arrow too when I came across this thread. I've found something that helped me figure it out.
There are two things this link doesn't tell you:
Having done that, it works like a charm.
I'm attaching the files I used for testing in case someone wants to see how. MDCBlocks is the "Container File".
Don Ireland
Engineering Design Technician
This dialog never populates for me when set to Current Drawing. Even when there is a correctly constructed north arrow block per the user guide. Empty all the time.
2013 North Arrows are here: C:\Program Files\Autodesk\AutoCAD Civil 3D 2013\Sample\Symbols\
2014 North Arrows are here: C:\Program Files\Autodesk\Autodesk AutoCAD Civil 3D 2014\Sample\Symbols\
2015 North Arrows are here: C:\Program Files\Autodesk\AutoCAD 2015\Map\Sample\Symbols\Map - North Arrows.dwg
To customize to your own north arrows, make a copy of the file (for backup of OOTB version). Use the one with the same name "Map - North Arrows.dwg" as the command looks for this drawing from this location. Go in and modify an existing north arrow by getting into the block editor on one of them and bringing in your custom north arrow.
These north arrows use Dynamic block Rotation Parameters to function - it is critical to maintain the existing parameters when modifying. You should see one named "Map.View.Rotation". When you bring in your north arrow you'll need to modify the parameter set to pick up your inserted linework. (see screenshot). Once that's done, close the block editor and save.
Remove any north arrows from the file you don't want used. Save the file as same name and same location on the PC. Close and reopen C3D. North arrow should appear and function properly.
Note - that there have been issues found with these north arrows. I don't recall the specifics but it's something to do with coordinate systems.
Steve Hill
Civil Designer / .NET Developer
AutoCAD Civil 3D Certified Professional
http://redtransitconsultants.com/
Autodesk Exchange Store
Twitter | LinkedIn
Please select the Accept this solution button if my post solves your issue or answers your question.
We have our company stardard arrows and scales that are working. I would like to use this option as another way to insert our own blocks rather than the autodesk standard north arrow block.
I could go update or change the North arrows.dwg file in this location C:\Program Files\Autodesk\AutoCAD 2015\Map\Sample\Symbols\Map - North Arrows.dwg to include our company block. but that would also mean i would have to do this for 220 plus cpu's and then have to do it again if something were to change or everytime we got a new hire. So I was wondering there was a way to change this default location from the current location to a network path? So it would make manange this file a whole lot easier in the long run.
thanks
Steve Hill
Twitter | LinkedIn
Steve Hill
Twitter | LinkedIn
I am not sure why everyone is ignoring the question. But if you want to populate the from current drawing box when using the North Arrow Layout Element on the Layout Tools ribbon all you have to do is temporarly unload all your Xrefs. You do not need to detach them simply unload them for the moment it takes you to select the block from your current drawing and than reload the Xrefs.
Warning. Using the North Arrow to set the rotation in the viewports will cause problems after just a few viewports in the same dwg - Civil 3D 2015 SP 3.
Nice workaround.
It's not that we're ignoring the question, it's just that the functionality of the routine is borked. Badly designed, hardwired names, poorly thought out, un-documented, and unreliable. Map3d (which is where this command comes from) seems to be neglected, and IMO the developers who created this functionality are off doing other things, and no one in Adesk management really cares enough about Map to fix it. After all, it's not cloudy enough for the C-Suite.
yes, it's a little static that the names of the two Parameters are fixed.
But that is not real a problem.
Now you will find the northarrow as userdefined inside the actuall drawing. Map and Civil controll
the exists of both parameter before listing.
You can also use a external drawing including all your own northarrows to insert your own northarrow
in a drawing.
I have attached the URL of a screencast I prepare in german. But it shows the steps I describe before.
Thorsten Scheel
Contelos GmbH - http://www.contelos.de
