Show only
Search instead for
Is there anyway to link text to a label instead of having to open up EditLabelText? It just seems like to many steps to add a simple comment to the labels. I'm doing a bunch of station/offset labels and some need to have a comments added. In the long run adding the text to the label is easier than just typing regular text below the label because you don't have to worry about not grabbing a piece of text when you need to move it but really there should be an easier/faster solution.
I'm I missing something?
btw on civil 3D 2011 if it matters.
One can add a double click action to a label to default to the Edit Label Text instead of properties to make it easier, through the CUI. I haven't seen anything to create a link to text though.
