hello,
i noticed that most of my linetypes are showing better if i set the ltscale to 5.0 .
also i read that the setting of ltscale should be 1.0 always (please note that i have litle experience with autocad and its behavior)
should i set it to 1.0 and find a way to "scale " the problematic linetypes to show as i want at ltscale=1.0 ?
is there a way to edit a lilnetype so it looks as i want in ltscale 1.0? by edit i mean only its scale Not the segments that made the linetype.
i am using 3-4 linetypes that i gather from friends and eatch should be scaled at diferent factor to show OK at the same drawing. so it would be very convenient for me if i could find a way to scale eatch one and the control the overal with ltscale.
hope i described the situation right.
thanks! i apreciate any help.
Achilles
Solved by Pointdump. Go to Solution.
Achilles,
Start with:
LTSCALE=1
MSLTSCALE=1
PSLTSCALE=1
Next, change the Annotation Scale to suit:
After that, you can change the appearance of individual lines in Properties:
Dave
Dave Stoll
Las Vegas, Nevada
Also ensure they are all loaded from the same file. In theory, metric drawings should be loading from ACADISO.LIN while imperial drawings should be loading from ACAD.LIN, but some companies have been using the latter for metric drawings with an LTSCALE of 5 or 10 for a looooong time and resist change.
Achilles,
Yes, you can edit a linetype. The AutoCAD Help Section has information on how to do that. But it might be easier to just make a Custom Linetype:
https://www.youtube.com/watch?v=SIdleZqu1XM
Dave
Dave Stoll
Las Vegas, Nevada
