Civil 3D Forum
line labeling
2 REPLIES 2
lgraham
171 Views, 2 Replies
line labeling
i need to label building dimensions in my as builts - Usually I will draw the building outline using a polyline - then when I label it i use - add label - line & curve - single segment and lots of times that works just fine labeling each side of the building - but sometimes I get line labels that give me the whole legnth of the polyline - could someone explaine to me what is going on
thank you
lgs
2 REPLIES 2
Jay_B
in reply to: lgraham
The "Property" set within the contents of the Label style composer is likely set to "General Overall Length" if using a Line Label style.
Change it to "General Segment Length" (which will label between line vertices).
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
rl_jackson
You might also look at converting that pline to a parcel. I use it all the time to label existing buildings and give the a little style. Crosshatch around the outside etc... Just need to use sites so they dont mess with other things.
Rick Jackson
Survey CAD Technician VI
Rail Community
