Civil 3D Forum
line label
17 REPLIES 17
Message 1 of 18
sturner7277
814 Views, 17 Replies
line label
i hope there is a simple solution to this.i think you will see from the pic my line mabel do not = the distance or property mesurement. all the labels are truncated so there is no auto rounding.. any ideas whay i am doing wrong i can reproduce this in2009 and 2012.
-Sean
Just a CAD Manager for a Civil Engineering firm...
17 REPLIES 17
Message 2 of 18
jmayo-EE
in reply to: sturner7277
If you are looking to get your labels to 2 decimal places you need to edit the label style.
John Mayo
Message 3 of 18
sturner7277
in reply to: jmayo-EE
that is not the problem. the problem is two different values for the same line.
-Sean
Message 4 of 18
Jason.Hickey
Are 168.48 and 168.4799 not close enough? One is rounded to two decimal places, one is rounded to four - when you introduce rounding into the mix, both numbers are techincally correct based on their significant digits. You have to realize that the *true* number is much longer, and even the one to four decimal places isn't the "real" number (no math pun intended.)
Jason Hickey
Premium Services Specialist
Message 5 of 18
sturner7277
in reply to: Jason.Hickey
Jason,
my problem is the label displays 168.4799 the line is drawn to 168.4800 WHY does the label display 168.4799 ???
 below is a link to my post on  the same type of problem i have with 2009.
https://forums.autodesk.com/t5/AutoCAD-Civil-3D/incorrect-line-length/td-p/3231702
-Sean
Message 6 of 18
jmayo-EE
Because that is the way things get rounded. Most plans use rounding. If you do not want it I will repeat my earlier advice. Edit or create a new label style. Set this up so it will truncate the value instead of rounding.
John Mayo
Message 7 of 18
sturner7277
I know how things get rounded. that is NOT the issue.
IF a line is drawn to a specified distance 168.480
i list the line it returns a value of 168.480
i view the properties of the line it returns a value of 168.48
i label the line using a OTB 'standard' style (modified to return three decimal places and set to truncate) returns a value of 168.479
is that clear enough or do i need to get the markers from the planners?
-Sean
Message 8 of 18
JeffPaulsen
I agree this is an issue. Can you please post the drawing I was not able to duplicate the problem here.
Jeff Paulsen
Civil 3D 2020.4 | Win 10 Pro N 64-bit
Xeon W-2223 @ 3.60GHz, 32GB Ram | NVidia Quadro P2200
Message 9 of 18
I agree, please post the drawing or at least the line in question. One thing... truncated is different from rounding. .4799 will truncate to .479 but round to .48. The first thing i'm going to do with the drawing is set my units to display 8 decimal places and look at the length of the line. All the listing you have done have been done at 2 or 3 decimal places.
Peter Funk
Peter Funk
Message 10 of 18
jmayo-EE
You have my appologies for sounding rude. It was not my intent. I responded very quickly on a busy day.
John Mayo
Message 11 of 18
sturner7277
in reply to: JeffPaulsen
here you go Jeff. it is saved using c3d2012 and zoomed into the line with a stock label.
thanks.
-Sean
Message 12 of 18
sturner7277
i can get a little punchy to i guess.
thanks to all.
-Sean
Message 13 of 18
JeffPaulsen
It appears to me that there is a defect when using the truncate rounding method. Using either Round Normal or Round Up provided the expected results. For now you may want to change your label styles.
I checked the actual length of the line and it is 164.48000000. I even drew a new line to make sure it was exactly 164.48. I tried chaging the line to other lengths and the defect may not always affect the label. For example a length of 120.48 displays correctly but 120.5 does not.
Jeff Paulsen
Message 14 of 18
Jeff_M
Some not-so-light reading to help explain why some numbers don't return what you think they should....
Read this ....
A very simple example: the expression 36.41 * 100.0 should return 3641, right? But in most programming languages, when the 'double' number type is used , this simple example always returns 3640.999999998. Of course when you apply the significant dgits rule this is correct (3641.0).
Message 15 of 18
AllenJessup
in reply to: Jeff_M
A little lighter reading on the subject: Between the Lines & Autocad vs. Microsoft Accuracy.
So one question would be - Is the OP working in a large coordinate system. Another would be why would a Civil 3D label experience the error when other methods of listing the line don't. I understand that different decimal setting will have different results.
Allen
Allen Jessup
CAD Manager - Designer
Message 16 of 18
JamaL9722060
in reply to: Jeff_M
Hi all,
How to labels the “regular” lines and points in the Civil 3D?
Jamal
Jamal Numan
Message 17 of 18
sboon
in reply to: JamaL9722060
Hello Jamal.
Reading through your recent posts suggests that you need to get a reference text like this one.  I know that local support or training is probably not available for you, but this book is available for download and includes tutorials and sample drawings which will help.
http://books.google.ca/books/about/Mastering_AutoCAD_Civil_3D_2012.html?id=oP8rpOolUmMC&redir_esc=y
Steve
Expert Elite Alumnus
Message 18 of 18
JamaL9722060
in reply to: sboon
Hi SBoon,
Right. I’m very new to the AutoCAD Civil 3D. Many thanks for the advice.
But for the time being, what i do to provide the length of each line is to get its dimension. I’m wonderin if there is a smart tool in the C3D that can handle this sort of thing such that the lines are labeled automatically.
Best
Jamal
Jamal Numan
Rail Community
