Civil 3D Forum
leader to node problems
6 REPLIES 6
djocwf54
387 Views, 6 Replies
I need to attach leaders to other places besides the center of the node.
Say its a water valve and id like to have the leader attach to the edge of the water valve symbol not
to the center where the node is???
I am labeling all the existing items in a survey and need to do this to different sized objects.
Attached is a pdf to show sometimes its hard to read the info with the leader in the way.
It wont let me point to any other spot.
6 REPLIES 6
Jeff_M
in reply to: djocwf54
PointStyle properties, Summary tab, Markers branch, first item is "Leader stops at marker". Set this to Yes for the leader to stop at the edge of the marker's bounding box, a No setting allows it to go to the actual point location.
djocwf54
in reply to: Jeff_M
looks like it already is set to yes
do i need to adjust point marker size
attached is showing the pointstyles
djocwf54
can anyone help with this problem??
Jeff_M
Looking again at the first image, it appears that one of the leaders is correctly stopping at the edge. Look at the end of the 1-1/2" water line, lower left coner. Is this a water meter? Is it using the WM point style? That's the one you showed the properties for. What do the point styles for the water valve and sewer manhole have for their properties?
djocwf54
here are the settings for my water and sewer manholes
Jeff_M
Could you post your drawing? If it's too big to post here, feel free to email it to me: jeffm AT quuxsoft DOT com
Rail Community
