Civil 3D Forum
layer isolation of xref layer
11 REPLIES 11
Message 1 of 12
1702 Views, 11 Replies
Could some please tell me how you layer isolate a layer in an xref?
11 REPLIES 11
Message 2 of 12
ACADuser
Sounds like a nice wish list feature....
Would be even more cool if it also worked on entities within C3D objects.
The only way I know > open up layer mangager, right-click then choose select all, turn off all layers then turn the xref layer back on.
ACADuser
Civil 3D 2018, Raster Design 2018
Windows 7 Enterprise
Dell Precision 5810 Workstation
Intel Xeon E5-1630 v3 @ 3.70GHz
32GB RAM, NVIDIA Quadro K2200 4 GB GDDR5
DUAL 27" Dell UltraSharp U2713HM
Message 3 of 12
I know in earlier version of cadd you can.
Message 4 of 12
ACADuser
Have you checked the customization group ? You might find some code that does what you need or if you are a bit nicer than I am you might just ask for it 😉
ACADuser
Message 5 of 12
mspatz
If you set your Layer Isolate back to locking layers rather than turn them off it works with Civil 3D objects; last I checked. Than what you can do is turn your lockfade %'age way up and the layers essentially turn off (slightly visible).
It is not the exact same but close'ish. If they only had a setting where object snaps would NOT see locked layers and other commands wouldn't interact with locked layers (ie: BPOLY command) it would be a perfect solution!
Message 6 of 12
jspeed
i found a lisp that will do it great...send email and i will send back....
Message 7 of 12
johnf261
I'm here looking for the old Land Desktop LAI command that worked great. It could pick nested entities.
Message 8 of 12
mspatz
Email me and I'll shoot you back a LISP that does the same thing.
Message 9 of 12
hey!
I would appreciate that lisp very much. I've been so frustrated at times. But what I'm consistently trying to do is isolate layers that are active and within an xref at the same time. Will it do that? If it won't work with both at the same time then it's useless to me. heh
thanks
Message 10 of 12
I'd like to get ahold of those routines as well.
Email: curtis.king@maxajen.com
Message 11 of 12
in reply to: mspatz
What is your email? does it end in y a h o o . c o m?
Message 12 of 12
Good morning,
Email is Curtis.King@maxajen.com
or cking8484@hotmail.com
I appreciate the assistance.
Rail Community
