AutoCAD Civil 3D General
Distinguished Contributor
MonkeyTrainer
Message 1 of 9 (643 Views)
lane slope, shoulder slope
643 Views, 8 Replies
11-07-2012 02:15 PM
how can i get my shoulder slope to match my lane slope? there is a feature line with elevation that is following the end of my lane (off: 33.50'). but from there, i cant get my shoulder slope to match my lane slope. i cant set another profile for the 35.5' offset to follow and need this to work. see image, dont worry about the left side.
thanks.
sboon
Message 2 of 9 (619 Views)
Re: lane slope, shoulder slope
11-07-2012 09:29 PM in reply to: MonkeyTrainer
Use a parameter reference in your assembly.  This will allow the program to apply an output parameter from one sub as an input for another one.
MonkeyTrainer
Message 3 of 9 (600 Views)
11-08-2012 08:01 AM in reply to: sboon
you are using assemblies that i'm not using. i cant get the assemblies you used to do what i need. i have specific alignments and elevations i need to follow and that sub doesnt have the juice i need, sorry. is there possibly another method you or anyone else can think of to help me out, i am stuck here... thank you SBoon.
sboon
Message 4 of 9 (595 Views)
11-08-2012 08:05 AM in reply to: MonkeyTrainer
Need more detail.  Post a sketch showing which subs you're using and how the assembly was built.  We'll also need to know which ones are being controlled by corridor targeting.  Can you post a drawing with the assembly in it?
Employee
peterfunkautodesk
Message 5 of 9 (594 Views)
11-08-2012 08:06 AM in reply to: MonkeyTrainer
What shoulder SA are you using? They should all have that override built in to allow the lane slope to be passed to the shoulder.
Peter Funk
Peter Funk
MonkeyTrainer
Message 6 of 9 (589 Views)
11-08-2012 08:23 AM in reply to: peterfunkautodesk
right now i am using a "lanesuperelevationAOR" defined by a feature line and elevation, and a "shoulderextendsubbase". i also have a "linkoffsetandelevation" before the lane.  you can see it in the image on the original post. i thought i went through the definition of the shoulder looking for something like that, but if there is another one i need to use i gladly switch. thanks.
MonkeyTrainer
Message 7 of 9 (585 Views)
11-08-2012 08:31 AM in reply to: MonkeyTrainer
SUCCESS! ok, i found the option to have it follow the lane slope. thanks to everybody that posted!
New Member
bmcd13
Message 8 of 9 (257 Views)
09-16-2013 08:36 AM in reply to: MonkeyTrainer
Hi - I have a similar problem and can't find the solution anywhere else.
I am using "ShoulderExtendAll" and I want to set my shoulder slope to 6% (easy enough) and set my subbase to 3% (also easy) but keep the shoulder base slope at 2% to match my road. There is no where to do this; the base slope automatically follows the shoulder slope (6%). Any ideas?
sboon
Message 9 of 9 (245 Views)
09-16-2013 09:19 AM in reply to: bmcd13
Please ask your question in a new thread - with a link back to this one if you like.  Posting a new question in an already solved one is generally considered a thread hijack.  It will not be possible to mark your issue as solved and others will have difficulty searching for it.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
