<->The result of lane slope report is zero in slope left and right...the superelevation view is ok and also the sections can anybody tell me what I am doing wrong?
Solved by Jeff_M. Go to Solution.
Please Note:
Include pertinent information.
No one know what version of Civil 3D you have, include SPs. OS also, Computer specs.
Bill
Lane slope report is zero in left and right slope.... sections view and superelevation view are ok. can anybody tell me what I am doing wrong?
I have Civil 3d 2014.
Windows 7 Professional
Processor: Intel (R) CPU ES-1603 @ 2.8 Hz
8.0 Gb Ram
SL Name Station Existing Ground Elevation Layout Profile Elevation X Y Slope Left Slope Right
0+000.00 0+000.00 498.976 498.308 1,156,814.721 1,279,669.135 0.00 0.00
0+010.00 0+010.00 498.395 498.103 1,156,811.549 1,279,678.619 0.00 0.00
0+011.55 0+011.55 498.176 498.072 1,156,811.057 1,279,680.091 0.00 0.00
0+012.00 0+012.00 498.102 498.062 1,156,810.910 1,279,680.514 0.00 0.00
0+014.00 0+014.00 498.223 498.021 1,156,810.142 1,279,682.359 0.00 0.00
0+016.00 0+016.00 498.203 497.981 1,156,809.194 1,279,684.120 0.00 0.00
0+018.91 0+018.91 497.817 497.921 1,156,807.517 1,279,686.493 0.00 0.00
0+020.00 0+020.00 497.913 497.899 1,156,806.802 1,279,687.317 0.00 0.00
0+025.00 0+025.00 497.635 497.796 1,156,803.005 1,279,690.551 0.00 0.00
0+026.27 0+026.27 497.422 497.770 1,156,801.926 1,279,691.212 0.00 0.00
0+027.00 0+027.00 497.419 497.755 1,156,801.288 1,279,691.576 0.00 0.00
0+029.00 0+029.00 497.409 497.714 1,156,799.552 1,279,692.568 0.00 0.00
0+030.00 0+030.00 497.404 497.694 1,156,798.683 1,279,693.063 0.00 0.00
I tried subassembly LaneSuperelevationAOR and gives me a good report exept that opposite sign
0+000.00 0+000.00 498.976 498.308 1,156,814.721 1,279,669.135 2.0% 2.0%
0+010.00 0+010.00 498.395 498.103 1,156,811.549 1,279,678.619 2.0% 2.0%
0+011.55 0+011.55 498.176 498.072 1,156,811.057 1,279,680.091 2.0% 0.4%
0+012.00 0+012.00 498.102 498.062 1,156,810.910 1,279,680.514 2.0% 0.0%
0+014.00 0+014.00 498.223 498.021 1,156,810.142 1,279,682.359 2.0% -2.0%
0+016.00 0+016.00 498.203 497.981 1,156,809.194 1,279,684.120 8.0% -8.0%
0+018.91 0+018.91 497.817 497.921 1,156,807.517 1,279,686.493 8.0% -8.0%
0+020.00 0+020.00 497.913 497.899 1,156,806.802 1,279,687.317 8.0% -8.0%
0+025.00 0+025.00 497.635 497.796 1,156,803.005 1,279,690.551 8.0% -8.0%
0+026.27 0+026.27 497.422 497.770 1,156,801.926 1,279,691.212 4.2% -4.2%
0+027.00 0+027.00 497.419 497.755 1,156,801.288 1,279,691.576 2.0% -2.0%
Dear Jeff_M,
I have the same problem in C3D 2022 like tonypalacio, but your solution doesn't work in my case. I tried to use the above mentioned subassembly and I tried also a generic subassembly using "Crown" and "ETW" codes.
Otherwise which file should I open in VB editor to see what point codes the report uses to determine the lane slope?
