Can't find a way to label a common rear parcel line w/ parcel label "span" option.
For instance, using example below, how do I label a span from point A to D and another from A to G? (Problem #1)
Also, I know I can label A-B, B-C, C-D, etc. without a problem. But, when I try to label E-F I get a dist for A-B and a separate dist for B-F. The sum of the 2 distances add up correctly but how do I force 1 distance when the rear lines are offset from each other? (Problem #2)
A B C D
|_________|_________|__________|
E F G
Any help or suggestions would be greatly appreciated.
Ed
