Darron Agawa wrote:
> This just started happening. k values most of the time show up as
> "???". Take a look at the attached pics. Both are from the same
> drawing and alignment, just at different times. Audit and reopen
> doesn't help.
From the two drawings you posted, it appears that crest curves aren't
showing the K value, while sag curves are. Is there a difference in
your label styles for sag and crest curves?
A previous release, Civil 3D 2005 (without any service pack), had a
defect related to this. Can I assume that you are using Civil 3D 2006, SP2?
Himanshu Gohel. Civil3D Team, Autodesk, Inc.
Autodesk Civil3D Product Information: http://www.autodesk.com/civil3d
