I need your help to check my answers
Q\When can an alignment subdivide a parcel?
A)When they are in the same site
B)When the parcels are ROW parcels.
C)When they are part of the same drawing file
D)When it is a design style
I think the correct answer is A
Q\How do you open the Alignment Layout Toolbar in an existing alignment?
A)Go to Home tab>Create Design panel & choose Edit Alignments
B)Select Alignments in the Prospector tab
C)Right click on Prospector and select Alignments
D)Select the Alignment in the drawing
I think the correct answer is B 'False'
I think the correct answer is A, C and D
Solved by ToddRogers-WPM. Go to Solution.
Q\ A profile view may be relocated by using the ACAD Move commandA) TrueB) FalseI think the correct answer is B 'False'
Q\How is the width of a lane within a corridor model changed? (select all that apply)A)Subassembly PropertiesB)Advanced PropertiesC)Assembly PropertiesD)Corridor PropertiesI think the correct answer is A, C and D
Q\In Create Intersection Wizard which tab is used to set the Curb Return Parameters?A)Corridor RegionsB)Geometry DetailsC)GeneralI think the correct answer is B
B)Select Alignments in the Prospector tab>> RC "Se'ect">>edit geo
Q\How is the width of a lane within a corridor model changed? (select all that apply)A)Subassembly PropertiesB)Advanced PropertiesC)Assembly PropertiesD)Corridor Properties: if target controlledI think the correct answer is A, C and D
Joe Bouza
