Is there a way to input PVI's based upon a know distance and slope. Say after putting in the starting PVI, entering say 250' at -0.4% and it will insert a new PVI and so on. I typically blast in the PVI's then use the geometry editor to correct, but someone had a questions and ive never done it that way.
cheers
jason
Solved by peterfunkautodesk. Go to Solution.
Use the transparent command "PGL" for Profile Grade Length. This will allow you to add points to your profile that are based on grade and distance from the last point selected.
Peter Funk
solid gold my friend. Is FDOT going to move to 2012. im involved with the beta with FDOT, trying to plan our future deployments.
cheers
jason
greetings mate
Howyabeen?
Joe Bouza
hola mr wordsmith, ive been good, trying to stay out of trouble. Hows things on your end of the world ?
cheers
jason
