Civil 3D Forum
information next to cursor alignment offset, surface elev, etc
6 REPLIES 6
1374 Views, 6 Replies
In 2014 Civil 3D when floating anywhere in model space next to crosshairs would pop up info. saying all offsets from all alignments and surface info. Now in 2015 it is only showing a maximum of 2 lines.  Just want to know where I can set that to display more.  I have already looked into dynamic input but that doesnt seem to be the right display for this info.
6 REPLIES 6
ToddRogers-WPM
Each alignment and surface have this option.  In the Alignment Properties, Information tab, check the box for Show Tooltips.  This has to be done for each alignment that you want to see in the tooltip.  Same for surfaces, Surface Properties....
Todd Rogers
in reply to: ToddRogers-WPM
All were already checked.  I have 10 alignments in drawing and multiple design surfaces. it will only show one alignment station and offset on first line, and existing ground elevation on second line.  Prior Civil 3D releases showed many more than two lines.
ToddRogers-WPM
What about in your Options, Display tab, is Show Extended Tooltips checked?
Todd Rogers
Also, the initial tooltip (reading the seconds from the Options) only shows 2 lines.  If you leave your cursor there, it should display the rest of them.  You can change the Number of Seconds to Delay to maybe 1 second.
Todd Rogers
thank you!  the show extended tooltips box under options was not checked.  now that it is everything works.
ToddRogers-WPM
You're welcome.  I like all of mine shown as well.
Todd Rogers
Rail Community
