AutoCAD Civil 3D General
MKH-VB
Message 1 of 20 (1,468 Views)
imported shape file and elevations
1468 Views, 19 Replies
04-12-2012 07:27 AM
I have an interesting problem.  I have imported a shp file from a state agency.  This file contains contours for an area.  When I tag the pline, it shows a "zero" elevation, but shows a numeric elevation within the DXF_ELEV feature.  Please see the attached image.  I am needing to convert these to pline with elevation to work on in autocad.  Can someone tell me how to get polyline w/ elevations to export from c3d?  Thanks for any help you can give.c3d elevations.png
mkh
Distinguished Mentor
thepworth
Message 2 of 20 (1,465 Views)
Re: imported shape file and elevations
04-12-2012 07:42 AM in reply to: MKH-VB
See if you can follow using the import & change properties by drawing query - I put a document together & posted in the following thread:
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Object-information-to-object-geometry/td-p/3367841
C3D 2011
Intel Xeon E5630@2.53Ghz
NVIDA Quadro NVS420 Dual Monitor
12GB Ram / Win7 Professional 64bit SP1
mathewk
Message 3 of 20 (1,456 Views)
04-12-2012 08:13 AM in reply to: thepworth
That query workflow is no longer required.  Civil 3D has a tool built in for that now.  Import Tab, Insert Panel.
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
MKH-VB
Message 4 of 20 (1,452 Views)
04-12-2012 08:16 AM in reply to: MKH-VB
C3D 2011?
mkh
MKH-VB
Message 5 of 20 (1,450 Views)
04-12-2012 08:27 AM in reply to: MKH-VB
that document loses me at number 6 iv.  Have no idea what "e234_mowest" is.
MKH
mkh
thepworth
Message 6 of 20 (1,447 Views)
04-12-2012 08:32 AM in reply to: MKH-VB
sorry, it was data specific for that user - I think I have the original document on my PC at home, but not sure.
In general, the idea was to mapimport the gis data into a drawing & create object data.  The we were transforming from the drawing with the imported data (contours at 0 elevation) and using a "alter properties during drawing query" to force the contours to the correct elevation.
I'm sitting in on a webinar today, so if you have specific questions, or want me to look at what you're wanting to do, I'll be happy to do what I can so I don't die of boredom here :smileyhappy:
C3D 2011
MKH-VB
Message 7 of 20 (1,444 Views)
04-12-2012 08:35 AM in reply to: thepworth
I am wanted polylines with elevations, so I can work on it in autocad. Is there a way for me to attach the cad file?
mkh
thepworth
Message 8 of 20 (1,439 Views)
04-12-2012 08:53 AM in reply to: MKH-VB
Create a new drawing & assign the coordinate system to match the .prj file from the shapefile.
Mapimport & create object data.  Make sure the object data includes the elevation assigned to the line in the shp file (shape files are 2.5D - elevation is an attribute).
then attach this drawing to your design/destination drawing in your design coordinate system. - from the "map explorer tab" of mapwspace, right click on drawings & follow the dialog to attach.
then query the drawing and use "alter properties" to assign the object data of the elevation from the shp to the z values of the resulting polylines.
detach the intermediate drawing & ignore the warning message.
HTH
C3D 2011
MKH-VB
Message 9 of 20 (1,431 Views)
04-12-2012 09:10 AM in reply to: thepworth
awesome....that did it.  Thanks much.
MKH
mkh
mathewk
Message 10 of 20 (1,416 Views)
04-12-2012 11:35 AM in reply to: MKH-VB
Not 2011, this is why it's important to include your version in every post you make.
Matt Kolberg
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
