AutoCAD Civil 3D General
Distinguished Contributor
Message 1 of 9 (130 Views)
imperial to metric scaling
130 Views, 8 Replies
03-07-2005 08:20 AM
Hi all,
I often work with very old maps and have to overlay them onto the modern OS.
I tried setting up a drawing with the units in feet and inches, and digitising a drawing, and then opening the modern map which is set to metres and importing the first into it, but the units in the first drawing simply turn into metres when it imports (so that something that was 1 foot in the original drawing is now one metre. Is there a way to bring a drawing done with imperial measurements into a drawing done with metres and have it automatically scale correctly?
Joan
*wfb
Message 2 of 9 (130 Views)
Re: imperial to metric scaling
03-07-2005 11:47 AM in reply to: albionpjl
Assuming no verticals are involved only horizontal, can you not insert one dwg into the other? Scale and explode the drawing. (1'= .3048 m) "albionpjl" wrote in message news:31943217.1110212430366.JavaMail.jive@jiveforum2.autodesk.com... > Hi all, > I often work with very old maps and have to overlay them onto the modern OS. > I tried setting up a drawing with the units in feet and inches, and digitising a drawing, and then opening the modern map which is set to metres and importing the first into it, but the units in the first drawing simply turn into metres when it imports (so that something that was 1 foot in the original drawing is now one metre. Is there a way to bring a drawing done with imperial measurements into a drawing done with metres and have it automatically scale correctly? > Thanks > Joan
Message 3 of 9 (130 Views)
03-08-2005 01:08 AM in reply to: albionpjl
Hi wfb,
I did do it that way in the end, but I have a vague memory from something I've seen somewhere (I don't remember where) that there may be a way for it to be done automatically with no need for further rescaling.
I may be mis-remembering, but given that architects and civil engineers must come up against this sort of thing fairly regularly, it seemed likely that a shortcut might exist.
Oh well
thanks anyway
Joan
*Angel Espinoza
Message 4 of 9 (130 Views)
03-08-2005 02:11 PM in reply to: albionpjl
It is possible to create the Civil Data (Point, Alignments, Parcels, Surfaces, etc.) in one unit of measure like Imperial Units and then LandXML Export to create a LandXML file. A user can then create a new drawing in Metric Units and LandXML Import. The software will convert the data from one unit of measure to the other. Clearly, this does not work for purely geometric objects (lines, arcs, circles, text, etc.). they can be inserted, aligned and exploded later. Angel Espinoza KETIV Technologies "albionpjl" wrote in message news:31943217.1110212430366.JavaMail.jive@jiveforum2.autodesk.com... > Hi all, > I often work with very old maps and have to overlay them onto the modern OS. > I tried setting up a drawing with the units in feet and inches, and digitising a drawing, and then opening the modern map which is set to metres and importing the first into it, but the units in the first drawing simply turn into metres when it imports (so that something that was 1 foot in the original drawing is now one metre. Is there a way to bring a drawing done with imperial measurements into a drawing done with metres and have it automatically scale correctly? > Thanks > Joan
*Doug Boys
Message 5 of 9 (130 Views)
03-09-2005 04:12 AM in reply to: albionpjl
No, That's the easiest and best way. What could be easier than scaling everything by the same factor ? If everything has the correct elevation in 3D you can even make a block of it all, delete all then re-insert with the same scale for X, Y and Z. Easy. Doug Boys
Message 6 of 9 (130 Views)
03-09-2005 05:28 AM in reply to: albionpjl
Hi doug,
I hoped that there might be an automated way that would use more decimal places in the conversion than are available to me in my last-year's-diary conversion lists (this year's diary doesn't have them), and would therefore have a greater level of accuracy over a large area.
thanks to all for the replies
Joan
Message 7 of 9 (130 Views)
03-09-2005 05:34 AM in reply to: albionpjl
having just done a search for conversion tables I see why they haven't bothered to make an automated way. I never knew that US feet were a slightly different length to Imperial feet. That would throw an extra variable into any attempt to do an automated conversion.
*Doug Boys
Message 8 of 9 (130 Views)
03-10-2005 03:51 AM in reply to: albionpjl
http://convert.french-property.co.uk/ http://www.simetric.co.uk/siinfo.htm There are even Philadelphia (?) feet which are different from US feet (by just a little bit apparently). Doug Boys
*Rad Lazic
Message 9 of 9 (130 Views)
03-23-2005 04:45 AM in reply to: albionpjl
Bloody Dutch, wearing wooden shoes! regs Rad "Doug Boys" wrote in message news:4230349b_1@newsprd01... > http://convert.french-property.co.uk/ > > http://www.simetric.co.uk/siinfo.htm > > There are even Philadelphia (?) feet which are different from US feet (by > just a little bit apparently). > > Doug Boys > >
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
