AutoCAD Civil 3D General
Valued Contributor
achillesgr
Message 1 of 5 (245 Views)
image disapears when zoom in geomap mode
245 Views, 4 Replies
10-08-2013 08:04 AM
hi,
i incerted an areas image with geomap but as i zoom cloce the image disapears and i get a tile with a white image of a camera. can i disable it? it is very annoying.i dont care if i loose ressolution if i get closer .why autodesk did that?
thanks!!
antoniovinci
Message 2 of 5 (230 Views)
Re: image disapears when zoom in geomap mode
10-08-2013 11:06 AM in reply to: achillesgr
Sounds like there's a Level of Detail depending on zoom factor...
Valued Contributor
achillesgr
Message 3 of 5 (220 Views)
10-08-2013 11:57 AM in reply to: antoniovinci
Yes but this happens in every location i look at.if i open the bing i can zoom any close i want .the resolution is bad if i go to close but i still can see what is going on.is there something i can do to disable the white screen? I am not even able to see my cursor as it is white on white.
Valued Contributor
achillesgr
Message 4 of 5 (195 Views)
10-09-2013 02:24 PM in reply to: achillesgr
Is there a way to fix this?thanks
New Member
BRYANJOHNSON2101
Message 5 of 5 (38 Views)
05-29-2014 06:37 AM in reply to: achillesgr
I would like to see this fixed as well bad resolution is better that white background
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
