Civil 3D Forum
how to use very much raw data in autodesk land desktop
6 REPLIES 6
ntwanabasu
322 Views, 6 Replies
I have raw data consisting horizontal angle with a base line( not N), horizontal distance, target height wrt station.
I need to use this data to make topographic map. can anybody help me out?
Tags (1)
6 REPLIES 6
antoniovinci
in reply to: ntwanabasu
No greetings, no thanks in advance: that's definetely not a nice beginning, man.
Moreover this is a Civil forum, while what you're after is here...
AllenJessup
Would you please post a sample of the data you have so we can see how it's laid out. Also, what format is it in? A TXT file?
Allen Jessup
Allen Jessup
CAD Manager - Designer
sboon
Given a horizontal angle, a horizontal distance and a delta elevation then it should be possible to create an FBK file which Civil3d can read and use to create survey points.  From there it would be fairly simple to build a topographic surface.
We need to see a sample of the data to answer further.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
antoniovinci
in reply to: sboon
Unfortunately the OP's using LDD, not Civ3D...
sboon
in reply to: antoniovinci
If I recall correctly Land Desktop can import and process FBK files also.
Steve
AllenJessup
in reply to: sboon
Yes. It can.
Allen
Allen Jessup
Rail Community
