using the modify > surface > add labels > slope function. how to show 2 decimal places instead of 1, like 1.2% to 1.25%. thanks.
Solved by doni49. Go to Solution.
Find the label style that it is using and edit that.
Settings-->Surface-->Label Styles-->Slope-->" "
" " Edit this style, probably using the 'Standard' style. Rt click-->Edit-->Layout Tab-->Component Name (change to 'Surface Slope')-->Text-->Contents...-->Highlight the component (ie the <[Surface Slope (.....|....)]> ) change 'Precision' to 0.01--> Click white arrow button to apply, then OK, OK
HTH
Follow the screenshots.....
Don Ireland
Engineering Design Technician
You're welcome. Glad to help.
Don Ireland
I am following these steps but for whatever reason it does not save it when I hit apply or OK. Any thoughts?
Nevermind, I missed hitting the arrow. Thanks for the help! Sorry, I dont know how to delete my initial comment.
