I see the same gap.
I create a station/offset label that pulls an elevation from a profile
(reference text). Model the corridor to get a decent idea of cut/fill, but
that's about it. I agree with you, it's nearly impossible to use it for
accurate labeling along an edge, especially at a curve - until some invents
the CIN (Curvalinear Irregular Network - and even then I wouldn't trust the
rounding in State Plane to paint an accurate model) - it is probably the
biggest complaint I have from clients as well.
If you do decide to label, the problem becomes - you can't export the
labels, and you can't convert them to point objects (out of the box - but
knowing you James - there is a way, but you'll need to write it). The
marker will have an object snap associated with it (insertion point if it's
a block), so a person could physically place points at all spot elevation
markers - but they won't be dynamically linked.
Ya, I feel your pain. The only other option is to model beyond the extents
of the curb, but when working almost vertical c&g, this can be a bear to
wrap your brain around (curve, compound curve, into a reverse curb).
sm
Scott McEachron
DCCADD Dallas - Fort Worth
http://c3dpavingtheway.blogspot.com/
"James Maeding" wrote in message
news:5525117@discussion.autodesk.com...
If I model a parking lot or street, using feature lines for curbs, I end up
with a surface that has trinagles only, not
true arcs.
When i go to place spot labels on the surface for TC's, they will almost
never actually hit the TC that the surface
actually models. For curved areas, the surface "chords" behind the true
curb line.
My spot labels will be off the true TC a bit, and this matters because the
face of curb is steep. A small offset
affects the elevation a lot.
This is not a new idea, it happened in LDT too.
How do most people model and label curbs? Is there a way to label based on
the feature lines of the surface?
I do it with alignments, but it would be nice to use surfaces.
On top of all this, corridors make surfaes that you can label, you cannot
label anything else that I know of with them.
Since the surface is faceted, it will not be reliable for labeling TC's
(fine for most everything else though, nothing
else has steep edges like curbs - maybe walls though...).
I know we cannot label directly off a corridoor, I've harped on that before,
but that leaves a gap in the system.
There must be a good strategy to cover this.
thx
James Maeding
Civil Engineer and Programmer
jmaeding - at - hunsaker - dotcom
