Civil 3D Forum
how to edit the band label settings?
5 REPLIES 5
mk9023
1305 Views, 5 Replies
settings > profile view > band styles > band sets > eg-fg elevations and stations > then what? where do i go to change color,height,precision, etc. Thanks.
5 REPLIES 5
jmayo-EE
in reply to: mk9023
 eg-fg elevations and stations is the Band Style that needs to be edited. In the attached hit the right Compose Label  button. That's where it all is.
John Mayo
mk9023
in reply to: jmayo-EE
i was able to change the station text height and stuff, but i can't find where to change the elevation labels, ie profile 1 shows precision 2 and profile 2 shows precision 3, i want to change that. can you be more specific on that?
mk9023
in reply to: mk9023
nvm i found it
jmayo-EE
in reply to: mk9023
Excellent. Here's a screen shot if anyone comes back to read this.
Once you hit the Compose button on the right you get to the Label Style Composer. On the Layout tab hit the Component Name drop down arrow to reveal all of the componets. The colors in use need to be changed for each component. Once you hit OK and return to the Profile Data Band Style dialog repeat the process for minor stations. You may also need to review the setting for the remaining items in the list.
John Mayo
jmayo-EE
John Mayo
Rail Community
