Civil 3D Forum
how to create expressionin structure reference alignment profile elevation
9 REPLIES 9
Message 1 of 10
537 Views, 9 Replies
i am create the stron network.I want structure profile elevation.
9 REPLIES 9
Message 2 of 10
tcorey
You don't need an Expression, you just need a Reference Text component in the Structure Label Style.
And then pick select Profile.
When you place the label, it will prompt you to select the profile for this reference.
Tim
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 3 of 10
in reply to: tcorey
i followed ur instruction. i try to shown profile elevation. But i could not get value.
Message 4 of 10
BrianHailey
Select the label, go into your AutoCAD properties, and select a reference profile.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 5 of 10
Joe-Bouza
I think the structure would also have to refer to the alignment of said profile
Joe Bouza
Message 6 of 10
in reply to: Joe-Bouza
i am already set strucuture refence alignment. But, how to get relavant station profile elevation..
Message 7 of 10
in reply to: BrianHailey
autocad property?? what is that? Are you mean structure reference alignment.
Message 8 of 10
Jeff_M
When you add a label for the structure, as long as the label style has the refence text for a profile included, you will be prompted to select the profile to reference. You can always go back and change or set it in the Properties Palette.
Message 9 of 10
It is ok.how to add reference profile elevation into structure table column.
Message 10 of 10
Thank you
Rail Community
