i am create the stron network.I want structure profile elevation.
how to create expressionin structure reference alignment profile elevation
Solved by Jeff_M. Go to Solution.
You don't need an Expression, you just need a Reference Text component in the Structure Label Style.
And then pick select Profile.
When you place the label, it will prompt you to select the profile for this reference.
Tim
Select the label, go into your AutoCAD properties, and select a reference profile.
Joe Bouza
