AutoCAD Civil 3D General Discussion
Active Contributor
darreng_oa
Message 1 of 3 (354 Views)
Accepted Solution
how to color a contour relative to the elevation
354 Views, 2 Replies
12-11-2013 06:21 PM
I would like the contour line colored to reflect the elevation it is depticting! I have successfully used surface properties - elevations - to create ranges, and to FILL color in between contours, but is there a workflow to color the contours themselves?
i also noticed, within the same dialogue box in surface properties, a contour pull down - but it doesnt have near the control to set elevation ranges, nor does actually effect the contour color.
any ideas?
TIA, OA
*Expert Elite*
Neilw
Message 2 of 3 (335 Views)
Re: how to color a contour relative to the elevation
12-11-2013 08:46 PM in reply to: darreng_oa
Under the Analysis tab of surface properties there is a Contour analysis. Apply a color scheme to the contours.
In the surface style settings you'll need to turn on the color scheme display. Go to the contour tab and under the Contour Range group, set "Use Color Scheme" to True.
Neil Wilson (a.k.a. neilw)
Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
WIN 7 64 PRO
HP Pavillion h8xt, i7 2600, 12 GB
RADEON 6450, 1 GB
http://www.sec-landmgt.com
Active Contributor
darreng_oa
Message 3 of 3 (255 Views)
12-21-2013 12:30 PM in reply to: Neilw
sorry to respond so late!
You are not logged in.
Announcements
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
