hi Everyone,
when the cursor is on the alignment obejcts, ROLLOVERTIPS show me ,
Ex,
Name ; AAAAA
Style ; AAAAA
Layer; AAAAA
Station Value ; 0 + aaa m, minus Aligment Profile 1 elevation , Exist ground profile elevation.
I want to Change ; Station Value = 0+ aaa m , Aligment Layout profile 1 Elevation / or anything else
How can I change that setting.
Hi Kaan,
The Station value shown in the ROLLOVERTIPS is based on what is defined in the "Text Component Editor-Contents".
You may want to edit the contents to your requirement by selecting the ellipsis button for the Text Contents in the Layout tab of the Label Style Composer as shown in the screenshot:
I hope this helps.
Hi Matt,
I hate to disagree but that has absolutely nothing to do with the roll over tool tips. If you want to change the precision of the tool tip, you need to go change the drawing setting or the feature setting. Please see the following video for the steps to do this:
Hi Brian,
I might be wrong, however my understanding to the question was about what is being displayed in the Station value for the ROLLOVERTIPS such as Kaan wanted no negative sign and something else instead of Alignment Profile elevation etc.
Thanks for pointing out.
