i have a table with a simple formula =sum(b3:b16) the formula works fine what i want to do is after the formula i want to add text. if the value of the formula is 22 i want the cell to read 22 V.F. i'm using civil 3d 2014
Solved by Joe-Bouza. Go to Solution.
Solved by tcorey. Go to Solution.
Right click, Insert Field.
Field category: Objects. Field Name: Formula. Type the formula, then press Addtional Format. In the Suffix box, type V.F.
Ok all the way out to the command prompt.
Best regards,
Tim
Joe Bouza
