I've got a profile view created with one surface and I would like to add a different tin surface...and keep the one surface already on it
thanks!
Solved by mathewkol. Go to Solution.
Profile - Create Profile from Surface
Then select the same centreline as the centreline in the profile you want to add the new surface
Select the surface you want to add and then add
Select draw in profile view and its there now just cancel out of the rest and done.
"Draw in profile view" does not need to be selected. It will just show up.
Select the alignment and add the surface from the Surface Profile option on the top ribbon
This worked perfectly for me. The only issue is that the bands does not update automatically, I have to access view profile props and click ok in order to get the band updated.
