Civil 3D Forum
how can we reverse alignment direction ???
3 REPLIES 3
basman12
3397 Views, 3 Replies
Hello everybody
is there is any way to reverse the alignment direction
3 REPLIES 3
miked
in reply to: basman12
Select the alignment the ribbon will change and on the tab with alignment properties - Superelevation ect. hit the flyout and there you will find reverse alignment. Make sure you use the flyout not the drop down from alignment properties
NVIDIA Quadro 600
Civil3D 2012 64x
Jozi68
How does one "hit the flyout"?  I cannot find this command.  I'm using C3D 2012.
troma
in reply to: Jozi68
The flyout is the part that "flies out" when you hit the little arrow on the bottom of the ribbon.
Mark Green
Working on Civil 3D in Canada
Rail Community
