what is the trick for holding triangulation within a surface boundary? I recall a setting somewhere but can't seem to find it... attached graphic, would like to hold the surface triangulation within the arcs which are in the surface definition as boundary
thanks,
Solved by neilyj666. Go to Solution.
Your Name
This may not solve your problem but it is worth noting that when adding the boundary to the surface definition you should enable the "non-destructive breaklines" option in the dialogue. That option ensures that the surface retains the triangulation precisely at the boundary. Essentially it is like clipping the TIN with a cookie cutter. If you leave it off the triangulation stops at the closest triangles that fall within the boundary. That usually results in gaps between the TIN and the boundary.
Make sure the Boundary is at the bottom of the operation list.
Allen Jessup
Allen Jessup
CAD Manager - Designer
thanks everyone, all suggestions were helpful
noted the mid-ordinate distance can also be set when adding a boundary
