Distinguished Contributor
nostupidquestions
Message 1 of 7 (140 Views)
hatch pattern issue (pattern to solid)
140 Views, 6 Replies
02-27-2014 07:52 AM
i've got a hatch pattern that is the DOT pattern for existing asphalt. it's annotative because i have 2 viewports, one at 20 scale and a detail at 5 scale. for some reason it randomly turns solid in the 5 scale viewport. am i missing something about annotative hatch patterns?
Dell Studio XPS 9100
Intel Core i7 CPU 930 @ 2.8GHz
12GB Ram
64 bit
C3D 2015
Jay_B
Message 2 of 7 (133 Views)
Re: hatch pattern issue (pattern to solid)
02-27-2014 08:08 AM in reply to: nostupidquestions
Are "Annoallvisible" and "Annoautoscale" both turned on on lower right of screen?
Is it actually being switched to Solid hatch pattern or is it a scale density issue?
Jay
C3D 2014 SP2
Win 7 Professional 64 Bit
nostupidquestions
Message 3 of 7 (130 Views)
02-27-2014 08:10 AM in reply to: Jay_B
it still says it a dot pattern, just showing up solid. this morning it was working fine. both of those toggles are on.
12GB Ram
64 bit
C3D 2015
nostupidquestions
Message 4 of 7 (123 Views)
02-27-2014 08:24 AM in reply to: nostupidquestions
there are actually two 5 scale viewports. one is dots and the other is solid. frustrating.
12GB Ram
64 bit
C3D 2015
Distinguished Mentor
JoAnn_Hogan
Message 5 of 7 (115 Views)
02-27-2014 08:50 AM in reply to: nostupidquestions
Would you mind sharing your drawing so we could have a look at the issue
Please let me know if this helps
Jo (P.S follow me on twitter @JoAnn_Hogan)
If this post solved your issue please mark as solved and Kudos are always welcome =)
AutoCAD Certified Professional 2014 / Inventor Certified Professional 2014
Jay_B
Message 6 of 7 (109 Views)
02-27-2014 09:03 AM in reply to: nostupidquestions
Hmm, Try using the "Match Properties" command. Select the edge of the good 5 scale VP then the Bad one.
Jay
C3D 2014 SP2
nostupidquestions
Message 7 of 7 (83 Views)
02-27-2014 11:29 AM in reply to: Jay_B
it's working correctly now. don't know what i did. thanks though.
12GB Ram
64 bit
C3D 2015
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
