Civil 3D Forum
grading surface crosses itself
4 REPLIES 4
exprexo
242 Views, 4 Replies
I have seen this problem many times in multiple projects. Mostly on grading surfaces I have noticed that the surface has contour lines almost cross-hatching the real contour lines. Is there an easy way to correct this, or is this a program gliche? I have purged, audited and have the latest service packs installed.
4 REPLIES 4
kcobabe
in reply to: exprexo
Have you tried turning on the triangles or moving into 3d view, or object viewer. The problem maybe that it's adding vertices to a feature line where it crosses an alignment or other feature line making the surface go up and down from z=0
R10 - 2020 ACAD
2008 - 2020 Civil 3D
2014 - 2020 Plant 3D
2014 - 2020 Revit
V8i - V8i SS4 Microstation
Infraworks
2018-2020 Inventor
2020 Navisworks
exprexo
No that's not the problem. These lines only stretch for 1 or 2 contours. Not to z=0 elevation although I have had that happen previously. I will upload a quick pdf showing triangles and the contours. They are just perpendicular lines to the contours in random places.
You have contour depressions turned on. Edit the surface style and turn off
contour depressions. It's in the contours tab.
Matt
exprexo
That fixed the problem. Thank you.
Rail Community
