I made a berm by creating a feature line from a closed polyline and then graded down to an existing surface. The bottom of slope is supposed to go around the entire perimeter of the berm but it only shows up on one side. If I view it with the object viewer it looks fine - the bottom of slope shows up all around the berm. What reason could there be for only part of the bottom of slope line displaying? Please see attachments.
Wil
If you go into the elevation editor for the bottom of slope feature line where you can see it, and go down the list of PIs in the editor, does it appear to stop or continue around? Watch the triangle highlighting the PI. Does it go around the berm or stop at the limit of what you see?
Mark Green
Working on Civil 3D in Canada
Are you able to open the file on another workstation? That might help determine if the problem is with the file vs. the computer.
Also make sure there are no errors in the file (AUDIT)
Kudos to Neil for suggesting Audit. Always should be a first port of call when something funky happens with feature lines. Do a save first, I've crashed a few times from doing an audit.
Mark Green
Check all layers on and thawed.
Regenall
Close drawing and/or program and/or reboot machine, try again.
.....normal checklist.
Mark Green
If you can post a reduced dataset, forum users can have a look. You might want to submit a support request and get the ball rolling.
See if this helps: Select the featureline>> autocad move >> enter enter.
Also was the FL created from existing entities? You may have had some pseudo nodes or doubl backs that would goop things up. Does the elevation edition indicate any split nodes the you otherwise would not have expected.
Joe Bouza
