Active Member
anamyslak
Message 1 of 6 (405 Views)
grading parking lot
405 Views, 5 Replies
02-03-2010 09:02 AM
Can someone help me?
I need to create cogo with elevations for stake out of parking lot. What Is there most efficient way to do this in Civil 3d? Thanks so much.
*Matt Kolberg
Message 2 of 6 (405 Views)
Re: grading parking lot
02-03-2010 09:07 AM in reply to: anamyslak
I assume you've actually designed the lot already with a surface? Just
place points wherever you want and then use the "Elevations from surface"
tool to apply the proposed elevations. Then you can export them to your
data collector.
Matt Kolberg
Global CADD Systems - A division of Cansel
Active Member
anamyslak
Message 3 of 6 (405 Views)
02-03-2010 09:40 AM in reply to: anamyslak
Hello Matt,
Thank you for your reply.
I will try to do this as I don't have much of experience with surfaces.
Thanks a lot again.
*Matt Kolberg
Message 4 of 6 (405 Views)
02-03-2010 10:12 AM in reply to: anamyslak
Good luck.
Matt Kolberg
"anamyslak" wrote in message news:6329587@discussion.autodesk.com...
> Hello Matt,
> Thanks a lot again.
Active Member
anamyslak
Message 5 of 6 (405 Views)
02-03-2010 12:09 PM in reply to: anamyslak
Matt,
I decided to do this in LDD :-)
I'm creating points "as I go" - with elevations of eop and top of drainage structures. Do I need to create also pnts with elevations on the sewer structures or storm and eop will be efficient for my surface?
Then I plan to build surface from pnts that I created and do pnts, create pnts - surface, random points.
Can you tell me what you think about this?
thanks
*Matt Kolberg
Message 6 of 6 (405 Views)
02-03-2010 12:34 PM in reply to: anamyslak
I guess it really depends if you are planning to have grade breaks at those
sewer locations. If not, there should be no need to create points there if
you're planning on making a surface.
Matt Kolberg
"anamyslak" wrote in message news:6329763@discussion.autodesk.com...
> Matt,
> thanks
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
