having the same problem when i use the "create feature lines from object" tool. When I use the "Draw Feature Lines" tool, the infill works. It is a bug.
Duane
Draw a feature line on one of the edges of the infil that is not included in the surface - seems to work, the infills then get included in the surface, happens mostly when feature lines are created from objects.
