Active Contributor
aluko0719
Message 1 of 4 (629 Views)
gis coordinate system display in civil 3d 2015
629 Views, 3 Replies
04-10-2014 10:04 AM
in civil 3d 2014 on the bottom of the screen you could dislpay the coordinate system. is there a way to show this in civil 3d 2015?
Distinguished Mentor
andrewpuller3811
Message 2 of 4 (592 Views)
Re: gis coordinate system display in civil 3d 2015
04-11-2014 05:36 AM in reply to: aluko0719
Try running the command "mapstatusbar" and then "s" for show.
This should turn on the map coordinate display and map scale displays on.
If this fixed your issue, click on "Accept as Solution"
Andrew Puller
Maitland, NSW, Australia
Windows 7 Enterprise 64bit
Intel core i7 2600 @ 3.40 GHz with 16GB Ram
Civil 3d 2013 64bit
New Member
txrain
Message 3 of 4 (254 Views)
06-25-2014 06:01 PM in reply to: andrewpuller3811
Thanks!
Valued Mentor
engrtech
Message 4 of 4 (238 Views)
06-26-2014 05:32 AM in reply to: aluko0719
It's also on the bottom right corner of the status bar. You'll see a button with three bars. Click that and you'll get the list of all the status bar toggles you can turn on/off, including coordinates.
Infrastructure Design Suite Premium 2014
Civil 3D 2014 x64
Testing IDSP 2015
Windows 7 64-bit
6GB RAM
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
