Civil 3D Forum
generic subassembly point coding best practices
1 REPLY 1
glacoste
243 Views, 1 Reply
what are the best practices for coding these subassemblies do you use L1 and R1 to seperate the left from right or do you keep both sides the same code. where is there a good tutorial on this?
Gerry
1 REPLY 1
fcernst
in reply to: glacoste
Typically keep the same code because Subassmblies have a "Side" parameter so that you can use the Subassembly on both sides of your Corridor.
Fred Ernst, PE
C3D 2024
Ernst Engineering
www.ernstengineering.com
Rail Community
