Try using Process Monitor from Microsoft. This creates a log of system
actions and it might show you what might be causing the drag.
Matthew Anderson, PE CFM
cstringer80 wrote:
> yea, I've tried uninstalling and reinstalling all drivers.
> Should I try to uninstall and reinstall .Net framework?
> Also, in the text style dialog, I can set a font and size, click apply and it works. As soon as I go to "Set Current" it freezes. Seems it freezes without even clicking, like the popup tips are causing it to freeze.
> And just now, after repeating it a few times to isolate some variables, the problem went away. After 3-4 crashes I fired it up did the same thing again and no freeze. Nothing else changed. working in the same drawing. this is weird and annoying.
